Drivers door wont lock with remote.
All of the doors lock with the remote except the drivers door. I have to manually lock it with the door lock button on the door before I close it.
1999 GMC Jimmy Thanks!!!!!!!
You have a problem with the door lock actuator on the driver door. Take the door panel off and check for proper power and ground at the connector to the door lock actuator when the lock & unlock buttons are pushed. If that checks out ok, then the actuator is at fault.
Thats what I was thinking it would be, thank you I will look!
travlinsouth
Jun 18, 2011 11:54 AM
4x4blazerguy
Feb 21, 2011 06:21 PM
