Driver's power seat rocks back and forth!
did a search to no avail. My drivers seat has the six-way power adjustable lower cushion and the whole seat rocks back and forth slightly when I accell and brake - annoying! I checked it out and the play seems to be located in the motor/actuator that adjusts the front portion of thetilt of the bottom cushion (frontmost up/down switch).
Anyone had to doa fix on this before? Thanks! -Mike
RE: Driver's power seat rocks back and forth!
bump, play is in the motor/actuator assy. nearest to the door jamb under the seat. If I replace this motor assy. will that fix it? anyone?...anyone?... Bueler?... Bueler?...
If you are sure that is where the 'play' is coming from well yes replacing it should solve your problem , just go to the wreckers and and get one there ....
Zed
Zed
I have the same problem. It just doesn't bother me enough to go buy a new assembly.
same prob here....annoying!
er0ck273
09-01-2013 11:45 AM
jmaynard
08-28-2010 03:56 PM
beilharzc
03-12-2006 01:50 AM
