Drivers side half shaft removal!
Old Sep 12, 2009 | 03:29 AM
skimorebutts's Avatar
skimorebutts is an unknown quantity at this point
Default Drivers side half shaft removal!
hey guys i blew the bearings in my front diff in my 2002 blazer zr2 and i am in the middle of just pulling the half shafts for now til my parts get in. i got the passenger side out fine but it seems there is some sort of trick to the drivers side... i can not get it loose from the case any advice asap would be great I NEED TO GET THE HALF SHAFT OUT!
someone told me there is clips or something in the drivers side... HELP!!!
Old Sep 12, 2009 | 12:31 PM
bump anyone have some advice?
Old Sep 12, 2009 | 04:08 PM
vaportrail's Avatar
vaportrail is on a distinguished road
Yes there is a ring that holds the tripot joint/ shaft into the differential gear. The ring should compress against a chamfer that is in the side gear of the differential. It will require some pressure. I have attached some instructions in a file. Not sure how to paste them in here. The ring will collapse into the groove in the shaft as it passes through the differential gear, and should remain on the shaft when you remove it. Hope this helps.
File Type: doc
Old Sep 13, 2009 | 04:37 PM
buck's Avatar
buck is an unknown quantity at this point
I used a 4' pry bar on the tripot joint and had a buddy pound on the tripot joint like the last post directions. It's a PIA and takes a while but keep trying it will pop out.
Wexinlo
Apr 6, 2011 11:35 PM
dman001948
Mar 28, 2011 07:18 AM
ddog800
14
Feb 16, 2011 03:01 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
