Driver's Side Window
Hi,
Driver's side window won't go up or down, when press the switch. I can however control any other window from the driver's side master panel and every other windows works with there own panel switch.
I noticed that replacement switches for the driver's side, replaces the entire master switch.
Is there anything I can check before replacing the entire switch, since the rest of it works fine.
Thanks
Peter
Thanks
Peter
Sounds like you have a bad window motor. If you can't hear anything when you press the switch, that would be the first thing i would check. Let me know how it goes.
Hi,
Thanks
Peter
Thanks
Peter
I had the same problem, was able to power the window motor directly with battery power, so I replaced the master switch and it works.
The driver window is the only one with a Auto Down circuit and an overload circuit in the switch, apparently one of those 2 functions failed.
I had the same problem. Up north- winter- window down! Bought a switch assembly and it didn't work. Thankfully Advance took it right back. Bought heavy plastic for 3 hour drive home. Got motor. 5 hour job. Nearly lost finger. Window worked! .....for about 4 months. Now nothin. Same symptoms. All others work. Window is up fortunately so I just grin and bear it.
mamawolf70
04-10-2020 10:44 AM
bjados
04-17-2008 04:25 PM
MindzEyeWRX02
03-20-2008 06:11 AM
hillbillyinOhio
07-12-2006 04:18 AM
