DTC code question
Old Apr 24, 2013 | 07:48 AM
Helter80's Avatar
Helter80 is an unknown quantity at this point
Default DTC code question
Hi all, my Service Engine Soon light is on, so I bought a code reader and the code is p0155 and p0155pd. now i understand that pd means pending, but why does it say the same code twice, and one is pending while the other is not pending?
Also, what is pending? Wouldn't it be bad or not bad? Sorry I am new to DTC codes, and the code scanner is the first one I have used. Thanks.
Old Apr 24, 2013 | 08:16 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
p0155: oxygen sensor heater circuit malfunction Bank 2 sensor 1. A pending code means it has almost met all criteria to show itself as a hard code. Existing codes can be a hard code and a pending because if the computer doesnt show the problem for ?? amount of time the code goes away, the reoccuring pending code makes sure the code isnt reset. Pending codes alone wont illuminate the Check engine light. This code is either a wiring problem with the O2's heater circuit or the O2 sensor is bad.
Old Apr 24, 2013 | 08:28 AM
Helter80's Avatar
ah, ok gotcha. but why would it show the same code twice? as a hard code, and again as a pending code? Bank 2 sensor 1, would be the O2 sensor on the passenger side exhaust manifold?
Old Apr 24, 2013 | 09:37 PM
cleburne red's Avatar
Yes. Bank 2, Sensor 1 is the first sensor on the passenger side.
Helter80
Apr 27, 2013 08:47 PM
thehustler211
Mar 13, 2009 01:49 AM
ESKYMOPACK
Jun 14, 2007 01:27 PM
justlookin
May 2, 2007 07:26 PM
fencr3
Apr 10, 2007 01:13 AM
