e-brake help
Old Feb 5, 2008 | 07:48 PM
thedopeshow912's Avatar
thedopeshow912 is an unknown quantity at this point
Default e-brake help
which tire or tires does the e-brake cable to go and what is the easiest way to replace it?
Old Feb 5, 2008 | 07:59 PM
Default RE: e-brake help
The e-brake cable goes from the cab to the rear axle. How to replace it depends on what it is you are driving (year, model, options, etc) and what part of the system is prompting this question.
Old Feb 5, 2008 | 08:06 PM
well its a 1997 blazer lt with 4wd, but to me, the cable seems like its fat and not too long..is there a place where it connects to another one? and it is fully loaded with abs and all of that good stuff.. the part of the system? well idk much about that as i said..the cable is kinda shorter and fat
Old Feb 5, 2008 | 08:19 PM
Well, lets start with what prompted you to look into the e-brake system. Is it not working? When you push the pedal is there resistance or does it just go to the floor?
Old Feb 5, 2008 | 08:25 PM
i mean, it works and all, but it doesnt release all the way sometimes..the lever pops back up, but on the tire it doesnt,
Old Feb 5, 2008 | 08:42 PM
You could try some WD40 in each of the cables where the cable goes into the sheath...
Where is the cable 'fat' as you state? At the wheel or where it goes up through the floor board on the driver's side? Is it only one wheel that is being problematic?
Old Feb 5, 2008 | 08:50 PM
well, i didnt look at it closely, and its not only 1 wheel..and i have one of the cables and its fat, i dont know which 1 it is exactly..im also trying to figure it out if there are 2 cables tht make up the brake cable, which looks like so because the fat one that i have is too short to be one long one..
Old Feb 5, 2008 | 09:12 PM
WolfPack's Avatar
Get a pic.
Old Feb 5, 2008 | 11:27 PM
Chevy Lover's Avatar
I believe that you have 3 brake cables. The front cable goes from the brake pedal through the floor to a connector. Then the left rear cable connects to the front cable. The right rear cable connects to the left rear cable by a connector that looks like this in the pic.
It would be a good idea if you jacked the truck up, put the back on jackstands, put the parking brake on and see if you can turn the rear wheels by hand. Then release the park brake and try to turn the wheels by hand to see if one or both rear brakes is stuck on.
[IMG]local://upfiles/2910/E3229C66E4614453A6F0BD89B964CF80.gif[/IMG]
zach bjorge
Mar 17, 2011 06:49 PM
SCBlazer96
Apr 16, 2010 08:39 PM
xderkax
Jan 14, 2010 11:38 PM
Hoelgi
17
Oct 20, 2007 08:49 PM
dashyman
Jan 12, 2007 11:28 AM
