electric 4wd
Old Sep 24, 2006 | 02:00 PM
crapgame's Avatar
crapgame is an unknown quantity at this point
Default electric 4wd
my 96 blazer wont engage into 4wd i have the push button 4wd on the dash and was looking for some input as to the cause of the problem... is there something wrong with the swith itself or is there something bigger that is causing the problem? hope to hear from someone soon!! thanks everyone!! mike d oh as an add on i know it isnt locking into 4wd because the lights for 4hi and 4lo stay solid and in the mud i was in i know only my rears were the ones spinning.... groan.... regards again mike d
Old Sep 24, 2006 | 03:01 PM
hillbillyinOhio's Avatar
Default RE: electric 4wd
First, check the fuse in the fuse panel on side of dash on drivers side. then we can start trouble shooting it. The switches are prone to failure, and if it is the switch, it will keep blowing fuses. Brand New switch = 40 bucks at a dealership
Old Oct 26, 2006 | 12:19 AM
Nemo's Avatar
Nemo is an unknown quantity at this point
I have a 2000 Blazer and had the same problem. The dealership said that I needed a new transfer case module. But I simply got under the truck, unplugged the module, cleaned it up and plugged it back in. Worked fine ever since.
Old Oct 26, 2006 | 11:27 PM
Brian J. Lesko's Avatar
Brian J. Lesko is an unknown quantity at this point
I had the same problem. I had a bad encoder motor. It wasn't that much to have fixed. I can't remember exactly, but it was under $100.
Old Dec 30, 2006 | 05:53 PM
crapgame's Avatar
Ok i did get the problem fixed.Under the battery where the seliniod(?) is that activates the 4wd there is a vac hose that came off and needed to be put back on..a VERY simple fix even for someone like me who went to the school for the mechicialy declined!
Happy new year all!
Mike D
aftermath8966
Jul 12, 2014 11:54 PM
50Chevy
Jan 5, 2013 04:44 PM
94fireblazer
Oct 8, 2011 07:13 AM
toyblazervt
Nov 28, 2010 05:07 PM
punx.inc
Dec 25, 2007 12:07 AM
