electric fan
Old Apr 17, 2013 | 09:34 PM
hillbillys10's Avatar
hillbillys10 is on a distinguished road
Question electric fan
I have a electric fan of off a 95 ford windstar with dual fans it is a inch taller and a inch longer than the original fan scrawl on the blazer any ideal on how to maybe make it fit are have any one done this I known that people on here said the 96 Taurus is a direct fit.this one free It off my windstart the transmission went out and it gone to coast more to fix than it worth and is there a way to make it to come on automatically like it did on the van and if i get it to work do i need to chance the thermostat to a different temp. thanks for any suggestions
Old Apr 18, 2013 | 09:01 PM
Is there something wrong with the fan clutch? It's far more reliable, moves more air faster, easier to diagnose & replace, no relays, no wires, no switches, no fooling around trying to make it fit. That's why rear wheel drive vehicles use them Front wheel drive had no choice, they had to settle for electric fans.
Old Jul 16, 2013 | 02:35 PM
I.B.Stuck's Avatar
I.B.Stuck is on a distinguished road
Lightbulb My E-Fan install
This is how I did my e-fan install. I did it this way because all parts were from junkyard and cheap, but reliable.
The Volvo relay handles all the power to the fan (This could also be used for dual fans). If you ground "IN 1", then power goes out through "OUT 1". If you ground "IN 2" then "OUT 1" goes dead and "OUT 2" is powered. I am told the Volvo relay will handle the draw of the Taurus fan on high. This is a new install for me so I have no lengthy experience. I located the temperature sensors in the heater hose going to the heater core. I did this by using some 1/2 inch copper pipe and fittings. I had to tap the threaded fittings to accept the metric threads of the temp sensors (I'm sure there is a better way to do this). You also have to make sure the fittings for the temp sensors are pointed down or on a downward angle to avoid getting an air bubble stuck in the sensors. The diagram should explain the rest.
Note: Wiring it this way gives you a switch cut off for four wheeling in mud/water, but will still come on when the AC is activated (in case you forget to turn the switch back on).
toyblazervt
Nov 28, 2010 05:07 PM
toxikchevy
Engine & Internal
Jan 26, 2010 04:27 PM
punx.inc
Dec 25, 2007 12:07 AM
chuckadian
Engine & Internal
Dec 1, 2007 12:00 PM
ivannj
Feb 14, 2006 07:10 AM
