Electrical problems
Old Feb 19, 2010 | 10:43 PM
NVANZEE's Avatar
we had a blazer in the shop the other day that was having a similar problem. It ended up being the positive battery cable going from the battery to the starter. It was shorting out on the frame or something. I cant remember. On the starter positive wire there should be a tab to make sure it is connected a certain way. If is not exactly right like the the one we had it might cause the cable to twist funny and rub against something metal.
Old Feb 20, 2010 | 07:31 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
I would suggest carrying a multimeter with you while you drive it. The next time it happens, leave the key on, measure the voltage between the negative POST on the battery and the terminal. if you see 12 volts, its a bad connection. Next measure from the post to the engine block. If you see 12 volts, you have a poor connection or a bad cable. Next check the ground cable to the body in the same way. You should show NO voltage (Or just millivolts at most). This will tell you if its a grounding issue. Good luck.
JoSHN
Sep 14, 2012 04:56 PM
upblazer95
Apr 4, 2009 08:27 PM
chris24301
Jan 24, 2007 11:01 AM
LT1KICKER
Dec 21, 2006 10:05 PM
joe
Apr 19, 2006 05:33 PM
