Electrical problems after radiator went bad
Old Oct 16, 2014 | 08:26 AM
hotredblazer's Avatar
hotredblazer is an unknown quantity at this point
Default Electrical problems after radiator went bad
I have a 1997 Blazer. Last May my radiator went out and sprayed anti-freeze all over the engine compartment. I replaced the radiator and cleaned it up as much as possible, and everything seemed ok. A couple of days later my battery was dead. I charged it up and noticed that the display on my stock radio was staying on when the key was turned off. I found the fuse that supplies power to the memory battery for the radio and removed it. This seemed to temporarily fix the light staying on problem, and the power drain, but obviously the radio/clock has no memory. I thought I could live with this until I had more time to troubleshoot. A couple of weeks later I was driving to work and the car started acting like it was stuck in second gear. I could give the motor more gas, but my top speed was maybe 30 mph. I don't know if I have a separate transmission problem now, or if this could somehow be related to the soaking from the radiator problem I had.
Thanks, Ken
Bolbol
Jan 23, 2015 01:22 AM
mxzretta
Apr 23, 2012 09:04 PM
MFerner41
Nov 24, 2010 05:05 PM
mtz57
Aug 21, 2010 10:10 PM
trocojo
Apr 20, 2010 10:11 AM
