Electrical Questions -- Needs answers
Old Aug 18, 2013 | 12:10 PM
2000BlackBeauty's Avatar
2000BlackBeauty is on a distinguished road
Default Electrical Questions -- Needs answers
Hi Guys
I have a 2000 Chevy Blazer LS 4 door model that has been doing some weird things here lately and i'm hoping to get some answers for solving them
1) - Voltage guage needle moves when Turn Signals are turned on .. it moves back n forth as each time the turn signal clicks
2) - When driving at highway speeds (55 mph plus) then starting to slow down like to get off an exit ramp I will get a Chiming noise from somewhere under the dash ... it continues to chime until I get to 35mph and then it stops
So does anyone here know what I need to do to fix these 2 little annoying issues????
Old Aug 18, 2013 | 01:42 PM
Spree's Avatar
Spree is on a distinguished road
If you leave your turn signal on to long it will chime at you so that you don't keep driving with it on. Not sure about the v-gauge.
Old Aug 18, 2013 | 09:28 PM
The volt gage might be related to the way the voltage regulator is excited. The PCM monitors charging voltage and controls the voltage regulator using a PWM, (Pulse Width Modulation) signal rather than the regulator directly sensing battery voltage. In low engine RPM and high current draw situations, you might notice the dash lights flicker slightly. This is a dead give away symptom of the PWM causing the problem. There is a GM TSB that addresses the condition and instructs to add a circuit to the voltage regulator connector at the alternator. This thread does a pretty good job eplaining how to do it: https://blazerforum.com/forum/tech-a...ference-60425/
Can't say for sure, but the chime might be related as well, or possibly a poor ground somewhere.
Old Aug 19, 2013 | 12:05 AM
Twip's Avatar
my work truck does the same thing as far as the voltage gauge goes. the funny thing is, if you put your 4 ways on, the voltage gauge probably wont move. mine doesnt, its weird. either turn signal and the gauge drops like you describe, put the 4 ways on, and no drop at all. lol.
the chime is from leaving your blinker on too long. it doesnt do it at low speeds so that way if you get stuck at a light you dont have to hear it. just like Spree said.
so to answer your question on how to get rid of them:
dont leave your blinker on so long.
maybe change the alternator....but it will probably still do it. just the way it is, at least with mine.
Old Sep 18, 2013 | 06:59 PM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
would this modification also apply if your volts drop with the a/c on?
Old Sep 18, 2013 | 07:05 PM
Your signature indicates that you have a 1995: It will not work on your 1995. Your voltage regulator already senses battery voltage.
Rockwood4
Jul 1, 2010 09:04 PM
newnin
Dec 16, 2009 02:13 PM
monsterblazer
May 29, 2008 08:34 AM
a_tack
Suspension Tech
Jan 15, 2008 10:09 AM
Tatiana05
Oct 29, 2007 10:33 PM
