Engine Bogging
Old Apr 11, 2012 | 10:27 PM
r0k0's Avatar
r0k0 is on a distinguished road
would a vaccum leak make the engine rev higher at idle ? also.. how do i check for a vaccum leak ???
Old Apr 12, 2012 | 12:38 AM
50lb_cat's Avatar
You may also want to clean your maf sensor and egr valve. Both of those can cause idle/power issues if they are dirty. When you pull your egr besure to get the new gasket with a screen in it.
Old Apr 12, 2012 | 08:02 AM
BuddyS's Avatar
BuddyS is on a distinguished road
To check if you have a vac leak, I would remove the vac hose where it goes in the intake plenum(drivers side), it goes to the same fitting the the PVC tube goes to, remove the smaller hose(not the larger one that goes to the PCV valve on the valve cover) and plug it with your finger or something, if the engine smooths out when pluged and runs better when you feather the acclerator linkage you may have a vac leak somewhere.
The vac hoses get very brittle and fall apart.
Old Apr 12, 2012 | 10:12 PM
r0k0's Avatar
if its the full pump not giving enough pressure when in WOT, or close to WOT would that make the bogging ?
Also would a Walbro 255lph fit in the GM tanks ? mine was bought for my old acura for my turbo setup but now i have it laying around could i use that or it would be too much pressure ?
rcooper1988
Jun 3, 2011 08:31 PM
powers9021
Jan 27, 2011 12:51 AM
DJ 4x4
May 8, 2010 11:41 PM
schimmi021
14
May 18, 2009 12:15 AM
Bigblock396
Jul 18, 2007 09:49 PM
