Engine cuts out - fuel pump?
Im having an issue with my blazer, while I'm driving down the road my motor cuts out, it sputters a little then comes back , every once in a while it dies. Before I tear into the fuel pump I just want some seconds that, that is what is is.
Thanks
Thanks
If it has enough fuel pressure could be a crank sensor...i've had one act this way and after figuring out it wasn't the module it ended up being this sensor...somehow it was actually keeping two cylinders from firing...just a suggestion good luck!
fixer34
Mar 16, 2014 10:45 AM
burned
Apr 26, 2013 04:14 AM
