LH FWD speaker cuts out
Old Mar 11, 2007 | 05:46 AM
Lee's Avatar
Lee
Lee is an unknown quantity at this point
Default LH FWD speaker cuts out
My left foward speaker, in the door, randomly cuts out. Is this just bad wiring, or bad speaker? I don't really wanna go tearing through my door panel to figure it out if it's just a bad speaker.
Old Mar 11, 2007 | 06:18 AM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
Default RE: LH FWD speaker cuts out
The connection might be loose to the speaker. Try to open and shut the door to see if that works.
Old Mar 11, 2007 | 10:33 AM
hillbillyinOhio's Avatar
sure osunds like bad wiring to me but it could also be a speaker gng out. sorry, only way to know for sure is to pull panel off.
Old Mar 12, 2007 | 03:56 AM
Lee's Avatar
Lee
I've done the ole "beat on it while driving" thing. Guess I'm just gonna have to pull it off. Hopefully it'll be a bad speaker, gimme an excuse to buy new ones.
Old Mar 12, 2007 | 11:16 AM
Yea the stock speakers suck anyways. When i get my car new in 01 i ripped those speakers out within 5k miles.
Old Mar 12, 2007 | 01:46 PM
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
The door panel romoval isn't so bad. There are one ortwo 7mm hex-head screws under the solid handle, you'll need deep sockets and maybe an extension to get those, then the phillips screw behind the latch handle. Other than those it's all christmas tree clips and the top of the door (by the window) wraps around the metal of the door. Put your window down so you don't scratch it and pull the panel away starting at the bottom, then lift it up.
If you know how to solder wires to tabs it would be a good idea (if they're actually loose) so you don't have to rip it apart again.
To put the panel back on just do that stuff in reverse order paying special attention to the top of the panel that goes near the window.
Old Mar 12, 2007 | 03:52 PM
Lee's Avatar
Lee
ORIGINAL: TheBrettster
They're actually not stock ones, previous owner installed Rockford Fosgate fronts and crappy Concept rears. Thanks 88, I just gotta find the time to do it, work is consuming my soul at the rate of 14 hours a day so I may just drop it off somewhere and pick it up when I have a weekend.
kgkern01
Feb 17, 2012 10:56 AM
hasek1616
Nov 6, 2011 05:21 PM
hambone8
Apr 14, 2010 01:20 PM
richjoe
Aug 21, 2009 07:07 AM
Paymeister
Performance & Brainstorming
Jun 26, 2008 08:30 PM
