Engine to Filter Oil Line
Old Feb 14, 2012 | 08:37 AM
bigcountry58's Avatar
bigcountry58 is on a distinguished road
Default Engine to Filter Oil Line
I have searched and failed on anything worth anything on this subject...
So this line started to leak pretty heavily, and I went to replace it. Upon getting it disconnected from the engine block, I could not get the damn thing to clear the transfer case. I need atleast another inch. Has anyone figured out a nice work around for this?
I have read about messing with the engine mounts, and I am not really in a position to do this... Anyone modify the lines to get it through?
Any ideas?
Old Feb 14, 2012 | 09:16 AM
chcknugget's Avatar
chcknugget is on a distinguished road
You could cut the old lines with a knife... Jacking up the motor isn't hard to do. There are two bolts for the motor mounts and two nuts on the transmission mount.
Old Feb 14, 2012 | 09:18 AM
Which means you didn't search enough...Or that you haven't tried what was presented.
If lifting the engine with a jack does not provide enough room to clear the front diff, then you will need to pull the engine mount bolt on that side to get enough clearance. You really can't modify the mounting lug on the end of the lines without diminishing the seal area.
If your mounts have sagged that much, they likely will need replacement sometime soon.
Old Feb 14, 2012 | 01:41 PM
Front Diff, yea I messed up the term quickly trying to write something out, my apologies... However, the damn thing has 60k miles on it and if I need to replace my mounts already, then f gm's. I have spent more money on this thing than I spent buying any previous car I have ever owned.
Its easy to accuse people of not looking or not trying, but short of removing the mounts I had attempted all that was offered. Was just looking for some more advice.
Old Feb 14, 2012 | 01:57 PM
Mileage doesn't matter when it comes to rubber components such as engine mounts. The age matters MUCH more. Age, even 9 years, with low miles is often worse than the same age with typical miles. In my experience, rubber components deteriorate faster when not in use.
And you seem to be letting your vehicle get the better of you...
You don't have to remove the mounts themselves, just remove the mount bolt to free the two halves of the mount.
Old Feb 14, 2012 | 02:03 PM
But that would lend to the thought that there would be some slop in the motor mounts yes?
We got no movement when attempting to jack up the engine.
I may very well be letting the vehicle get the better of me, I have spent more time inside of it then my wife... and cost me more money!
Old Feb 15, 2012 | 07:43 AM
chcknugget's Avatar
Remove the two nuts holding the transmission to the crossmember and the motor should lift up... Its very possible your motor mounts are toast so the whole thing should lift up easily. I had enough room to feed the lines above my front diff without jacking the motor up so your motor is sagging. What kind of jack are you using?
adamscottmartin
Jun 26, 2013 11:31 AM
cleburne red
Jan 28, 2013 04:53 PM
maddie's dad
Jun 12, 2012 12:43 AM
bigbonedmutt
May 13, 2011 11:00 PM
knightryderx2
Mar 8, 2011 10:39 PM
