remote oil filter line replacement
Old May 9, 2011 | 09:20 PM
bigbonedmutt's Avatar
bigbonedmutt is on a distinguished road
Default remote oil filter line replacement
Ok I know that this has been discussed on here before at some point. I need to replace the remote oil filter lines and there just isn't any room to get the old ones out. Any suggestions would be helpful. Surely Gm wouldnt have made them impossible to change? 1994 S-10 4X4 blazer 4.3 engine
Old May 10, 2011 | 01:49 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
On my 94 I had to pull a little and turn them a little, etc. They aren't easy but will come out. I swore they wouldn't either.
Old May 10, 2011 | 05:24 AM
How about putting the new ones in? Did you manage to get them out from top or bottom, front or rear?
Old May 10, 2011 | 11:45 AM
4x4blazerguy's Avatar
What I was told is loosen motor mount & jack up the engine a little. That is what had to be done with my 97 Blazer 4x4.
Old May 10, 2011 | 09:55 PM
Not an easy task either.
Old May 10, 2011 | 10:11 PM
chris015's Avatar
Hardest part was getting the lines loose. I JUST finished mine a week ago.
Use 4-5 6" extensions throught the front of the truck to get to the bolt that holds the lines to the adaptor,and you MUST use some kind of silicone to keep the gasket from sliding off the adapter putting it back in. Also use some black electrical tape and wrap 2 layers under the head of each bolt so they dont fall out when you try to reinstall the adapter. other then that,its alright...but honestly..id never do it again lol
Old May 11, 2011 | 09:06 PM
The bolts were easy. Which way did you take the lines out? Top, Bottom, Front or rear?
Old May 13, 2011 | 11:00 PM
Took mine out from the front. Just go slow and they will flex a little as you pull them. Lossen all the clamps. I didn't have to jack the engine though it probably would have been easier.
TDS-MN
Jan 7, 2015 01:23 PM
adamscottmartin
Jun 26, 2013 11:31 AM
rllamarca
Apr 22, 2009 11:23 AM
doodad69
Dec 1, 2008 01:44 PM
etek ego
May 17, 2008 10:05 PM
