hellllp leaking everywhere
Old Feb 15, 2012 | 11:54 AM
97blazzer's Avatar
97blazzer is on a distinguished road
Angry hellllp leaking everywhere
well had 97 blazer for one week now and im pissed off, its got coolant comeing out where the intake manifold runs on side with valve cover and leaks more when givin more gas so is that a headgasket? what should i do? its leaking and comeing right down by the starter bolt but u see it build up more water up by intake manifold or well lower intake when revved so idk wtf too do
Old Feb 15, 2012 | 12:13 PM
rriddle3's Avatar
If the leak is above the valve cover then it is almost assuredly the lower intake manifold gasket, but a coolant pressure test will confirm it.
Old Feb 15, 2012 | 02:53 PM
warthogdriver's Avatar
Def sounds like intake manifold gasket is shot. Check your oil asap for cross of fluids.
mine leaked in same spots in valley along valve covers. There is a how to on the forums.
it took me 12 hours to do...was a learning exp. If you do it yourself get the felpro gaskets with a 'T' in tha parts code. Gaskets cost me 90 something.
good luck
Awesome
Feb 14, 2014 09:45 PM
mattbo324
Feb 2, 2013 11:50 PM
KA3AX
Jan 15, 2007 01:33 AM
skitzobmxr
Dec 14, 2006 09:38 PM
BlazinFire
Aug 6, 2005 01:51 AM
