Engine Hesitation when using heater?
in my 2000 gmc jimmy, I have noticed that when i turn my "Heater controls" to anything other than off the engine has a hesitation while accelerating. If i put it on A/C then i would understand cause of the extra load from the compresor. But when i use the heater weather it be on the floor, vent or defrost, the engine hesitates while accelerating, and i have to freeze my butt off till i hit highway speed. and this happens weather the engine is cold or at temp.
And i dont know if this is related to my problem, but when i do have it off i notice air is coming out of the floor vents. The faster my speed the harder the air blows out of it. Noticed it one day on my way back from work when my foot flet like it was on fire, lol.
I know theres other threds about hesitaion, but i havent noticed any being because of the heater use.
Possibly a vacuum leak as well, I had an issue that when I had my ac/heat on it would go through all vents... Found that 2 separate hoses were disconnected one on the drivers side and one on the passengers side.
I too had a slight hesitation, but it was nothing major. Just noticed that it would almost skip a beat.
How bad is yours?
How bad is yours?
You can eliminate the compressor by pulling connector off the accumulator bottle.
Airflow is supposed to stop in off position. Blend door cant stop airflow from the cowl
What happens when you switch to max ac?
Most likely you have a leak in an actuator diaphragm or a line that's loose.
Under dash, engine running, listen for hiss in all positions.
rockhard69
Feb 13, 2012 09:52 AM
88s10Blazer
Jun 20, 2006 05:56 AM
shaka1111
Feb 13, 2006 02:23 PM
