Engine knock sound
Old Apr 11, 2025 | 03:19 PM
jimmy_for_ever's Avatar
jimmy_for_ever is on a distinguished road
Exclamation Engine knock sound
Hello everybody,
I have serious problem in my 00 gmc jimmy. When I start the car there is high knocking sound and if I increase the speed or rpm the sound become louder and the oil pressure bouncing on the middle and there is oil leaking from the center bottom of timing cover.
The car odometer 375,429 KM
Anyone was having same issue before ?
Thank you
Old Jun 8, 2025 | 01:26 PM
It is possible that flex plate cracked ?
Old Jun 8, 2025 | 01:44 PM
A cracked flexplate will make noise when the load on the drivetrain is low and/or changes quickly (in neutral/park, you quickly let off the throttle while driving, etc.). Typically, a cracked flexplate would quiet down under acceleration as the load would close the crack.
If your observations are made in park/neutral, then it may be possible that the flexplate is the culprit.
I'm not sure what you are referring to about the oil pressure bouncing. Perhaps you could elaborate a bit more on that point?
Old Jun 8, 2025 | 04:12 PM
Thank you for your reply, I oil pressure gauge bouncing
blazergurl95
Feb 12, 2014 12:50 AM
siddhartha
Mar 23, 2012 06:47 PM
Absit
17
Nov 4, 2010 06:06 PM
Chevy33
Jun 2, 2010 09:16 AM
natebluecat
Jan 2, 2009 03:09 PM
