Engine never reaches operating temp
Old Jul 27, 2018 | 06:19 PM
RedBlezer's Avatar
RedBlezer is on a distinguished road
Question Engine never reaches operating temp
I've had this issue with work trucks before and have always dismissed it.
The temp gauge only tells me the engine has warmed up 1/4 of the way. After 1hr+ of driving, it stays at 1/4 warm. If theres any clear cut solution to getting the engine to operating temperature itd be appreciated. I feel like a lower operating temp will impact my mpg.
Its a 2000 blazer btw. Had it for 6 weeks or so.
Oil pressure is always at at least 1/2 - 5/8. Just did an oil change. Coolant was low in the reservoir when i bought it & have filled it up to no avail.
Old Jul 27, 2018 | 10:02 PM
GeorgeLG's Avatar
First you need to confirm the actual coolant temperature. Whats the ECT temp on a scanner? If you have an IR gun, shoot the sender area and the thermostat housing.
George
Old Jul 28, 2018 | 08:11 PM
AJBert's Avatar
Replace the thermostat, their cheap. Or if you are really tight on fund, test the thermostat and then replace. My guess is your thermostat has failed in the open position, as they are designed to do.
Old Jul 29, 2018 | 01:48 AM
RedBlezer's Avatar
George
I dont have a scanner yet.. cheapie ones on amazon worthwhile? definitely dont have an IR gun lol thanks for the suggestions though
Ok, i hear ya. Ill give it a go.
Old Jul 29, 2018 | 02:39 PM
GeorgeLG's Avatar
If you have an android device, Les can get you set up with a blue tooth dongle and software. That the most capability for minimum outlay. I bought a used android tablet on eBay and a BT dongle on Amazon. I have since moved on to a high scan tool but before all of this, my first Actron was a good basic scanner. In nova also seems to get good marks. Maybe someone here can recommend a current model if you don’t go the android route.
George
Old Jul 30, 2018 | 04:09 AM
You said that you have replenished the coolant "to no avail".
What does that mean?
That the coolant level is low again?
Old Aug 3, 2018 | 02:54 PM
RedBlezer's Avatar
Smile
George
Thanks for the tips, I dont have an android unfortunately. Ill probably just get something cheap off Amazon
To no avail of the coolant temperature problem. The coolant level has stayed the same since i filled it up.
Old Aug 5, 2018 | 01:58 PM
Rusty Nuts's Avatar
What kind of gas mileage are you getting? If it's low that could tell us if the engine is actually cold or if there's a problem with the temperature signal or gauge.
Old Aug 5, 2018 | 07:36 PM
RedBlezer's Avatar
Last fill up has gotten me 270km (168 miles) and im down to my last 1/3 or 1/4. Will provide more accurate info next time I fill up. Good mix of city/highway driving. Whats a full tank usually get you guys range-wise?
Old Aug 6, 2018 | 07:47 AM
GeorgeLG's Avatar
17 mpg
George
97cherryblazer
Mar 3, 2012 06:01 PM
RIFLEMAN 308
Dec 19, 2010 07:11 PM
95BlackBetty
Nov 11, 2008 09:49 PM
dave5514
Jan 15, 2008 08:45 AM
mrspeedy69
Apr 27, 2007 01:12 AM
