engine power loss shut off
Old Aug 7, 2011 | 06:18 PM
A '95 doesn't have the splice pack that was causing all of his problems. You could check the frame grounds that are near the fuel tank though.
Old Aug 8, 2011 | 08:21 AM
gaspricessuckk's Avatar
gaspricessuckk is on a distinguished road
hm. crap maybe it just needs a tune up or maybe the fuel pump is bad
Old Aug 8, 2011 | 10:14 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
You can try to guess the problem and quite possibly replace good parts before you find the right one. OR you can troubleshoot the problem and save money! You need to check the fuel pressure.
Old Aug 8, 2011 | 11:15 AM
We are doing the egr vavle cleaning now
Old Aug 8, 2011 | 12:44 PM
xgiovannix12's Avatar
if cleaning the egr valve doesn't help any thing i suggest checking the fuel pressure and starting off from there before you trow any more crazy money into parts
Old Aug 8, 2011 | 01:12 PM
Egr didn't do anything what is the fuel pressure supposed to be
Old Aug 8, 2011 | 02:04 PM
When you turn the key on the pressure should be 55-60. it must be able to hold a pressure above 52 for 10 minutes
any ways if it dont hold it might be a leaking spider injector or weak fuel pump
Old Aug 8, 2011 | 08:49 PM
Well we sttill don't have a gauge but the fuel is spraying a lot
Old Aug 8, 2011 | 08:53 PM
It wouldn't matter if its spraying a lot if its got enough pressure we need to worry about.
Old Aug 8, 2011 | 11:54 PM
Yeah that is true. Just sucks I have no money to keep buying ****.
