engine power loss shut off
Old Aug 6, 2011 | 11:31 PM
gaspricessuckk's Avatar
gaspricessuckk is on a distinguished road
Default engine power loss shut off
95 blazer Ls with about 176k. engine likes to sputtered, shut down when stepping on the gas. I out it in n and restart keep going. I have read a few threads on the issue but want to ask if anyone has a clue. No its not the.catbcause I cut it off and its doing it.
I have read fuel pump, ecm, them pump connector, but the problem comes back. it only got extremely worse after I went mudding last week. its summer here, always above 80 and humid.
Old Aug 6, 2011 | 11:45 PM
xgiovannix12's Avatar
did you get fuel pressure readings ?
Old Aug 6, 2011 | 11:52 PM
I don't have anything to read that. As it shuts off bogs down w.e my oil pressure drops
Old Aug 6, 2011 | 11:59 PM
sounds like your having fuel problems . the only way you can find out is by doing a leak down test on it
Old Aug 7, 2011 | 12:01 AM
Like I said I read a 8 page thread on the same issue and he replaced his fuel pump 3 times
Old Aug 7, 2011 | 12:05 AM
this is a fuel injected truck right ? it could always be a leaking spider or fuel pressure regulator . also sometimes the ecm fails that might be it too but its not worth trowing in parts in till its diagnosed
Edit : how old is the fuel filter ? do you got a ses light on?
Old Aug 7, 2011 | 12:26 AM
No ses light unless it burnt out. And should be fuel injected
Before when I would step on the gas and the engine would bog down the ses light would blink for a while stay on for a while then shut off. That was before the truck would shut off
also it's idling a little funny, sometimes feels like 2000 rpm and then it drops, like the 02 sensor is bad, but i just replaces 02 sensor 1 bank 1 in july
Last edited by swartlkk; Aug 7, 2011 at 11:55 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Aug 7, 2011 | 10:12 AM
did you ever clean the egr valve ? that could cause bad idle
this might help you with that
https://blazerforum.com/forum/articl...-thread-18901/
whens the last time a tuneup was done to the truck ?
Old Aug 7, 2011 | 12:10 PM
xgio... It's a '95. Of course it is fuel injected...
gas, A blinking CEL is an indication of a misfire. The CEL should illuminate during the bulb test when you turn the key to the 'run' position so you can check to be sure it isn't burnt out. Given the tendency for the CPI engine to have fuel problems, I would definitely recommend getting a gauge to test the pressure.
Old Aug 7, 2011 | 06:15 PM
https://blazerforum.com/forum/2nd-ge...m-42968/page2/
I also found this I have like the same problem he had
