my blazer smokes when in 4wd
Old Nov 24, 2010 | 09:31 PM
MetallicaFreak24's Avatar
MetallicaFreak24 is on a distinguished road
Default my blazer smokes when in 4wd
i got a 95 2 door blazerwith 202000 miles. everything has been done but the transfer case engine, and the body/chassis. when i put the truck in 4wd it'll starting putting out white smoke after a few minutes, then when i put it back in 2wd it stops after about 5 minutes. i have no clue whats wrong or how to fix it. PLEASE HELP!!!
Old Nov 24, 2010 | 11:58 PM
blazerpower's Avatar
blazerpower is on a distinguished road
how often do you use the 4wd
Old Nov 25, 2010 | 08:23 AM
RonJon's Avatar
RonJon is an unknown quantity at this point
Replace the vacuum switch on the transfer case. It's sucking in tranny fluid in the 4WD position (my guess)
Old Nov 28, 2010 | 12:32 AM
i don't use it that much, but when i do it scares me, that truck is my baby ya know?i don't know how it could be the vaccum switch, cause it comes out the tail pipe, which doesn't make sense to begin with. how would 4wd make the truck smoke like that? this has had me puzzled for almost a year
Old Nov 28, 2010 | 12:45 AM
have you checked the fluid in the transfer case?
Old Nov 28, 2010 | 09:23 AM
If you have fluid in the vacuum lines, you likely have two issues; 1- bad transfer case input seal on the front of the transfer case & 2- bad vacuum switch.
To check for a bad input seal on the t-case, pull the fill plug on the back of the t-case. If fluid pours out, then the input seal is bad and the t-case needs to be dropped.
blazingtrails93
May 30, 2011 04:06 PM
corhey88
Jan 21, 2010 06:28 PM
2001 ZR2
Jan 16, 2010 12:39 PM
aspenrebel
Dec 12, 2007 05:52 PM
pfanni
Jan 25, 2007 12:42 AM
