Engine won't crank
Ok, I figured because winter is knocking and will soon be here, I wouldn't be using a/c, I could just bypass it for now if possible,until the summer comes around again. I am guessing this is not an option.
I really don't mind if I have the a/c or not, even in the summer, hardly use it at all, as temps are mid twenties (Celsius) here in summer.
I read a post that some guy bypassed with a belt (83.5"), but that was all that was said, never stated if he had problems after or not. Curious as to if this would work because atm, I don't have the cash to fully repair until I get back to work next month.
Thanks again
Darryl
Thanks again
Darryl
Chevrolet Blazer Dayco Drive Belt - 1996-2004 Chevrolet Blazer - Dayco DY5060870
That is correct. My a/c pulley is on the right above my p/s pulley. I can see straight from the a/c pulley to the p/s pulley...it is aligned.
Only way to be sure is to measure the travel distance of the belt, and if that path will be the same as a similar engine with no a/c, if I want to get a belt that will fit correctly.
I guess the main question is now, if I do find a suitable belt that fits (bypassing the a/c unit), will it be okay to do so or will it cause more problems?
Thanks, yet again people. This is greatly appreciated!!!
Darryl
Darryl
The clutch bearing replacement *IS* the cheap option. Doesn't require the system to be opened up, just a bearing replacement.
The thing is it requires special tools {may rent from Autozone 'free} to remove and may be a little more difficult given the bearing spun.
But I would definitely check out the option. It's what I would do and I have all the AC service tools.
And that belt for 'w/o' is meant for the factory ac delete pulley.
Buddykitchen
12-10-2016 06:37 PM
keifer56
01-24-2008 10:27 AM
