Engine won't crank
Old Oct 13, 2011 | 10:16 AM
dobyken's Avatar
dobyken is on a distinguished road
Originally Posted by Darrylj
Ok, I figured because winter is knocking and will soon be here, I wouldn't be using a/c, I could just bypass it for now if possible,until the summer comes around again. I am guessing this is not an option.
I really don't mind if I have the a/c or not, even in the summer, hardly use it at all, as temps are mid twenties (Celsius) here in summer.
I read a post that some guy bypassed with a belt (83.5"), but that was all that was said, never stated if he had problems after or not. Curious as to if this would work because atm, I don't have the cash to fully repair until I get back to work next month.
Thanks again
Darryl
There's a belt listed for 2004 without A/C...not sure it it will fit or not.
Chevrolet Blazer Dayco Drive Belt - 1996-2004 Chevrolet Blazer - Dayco DY5060870
Old Oct 13, 2011 | 11:52 AM
Darrylj's Avatar
Darrylj is on a distinguished road
That is correct. My a/c pulley is on the right above my p/s pulley. I can see straight from the a/c pulley to the p/s pulley...it is aligned.
Only way to be sure is to measure the travel distance of the belt, and if that path will be the same as a similar engine with no a/c, if I want to get a belt that will fit correctly.
I guess the main question is now, if I do find a suitable belt that fits (bypassing the a/c unit), will it be okay to do so or will it cause more problems?
Thanks, yet again people. This is greatly appreciated!!!
Darryl
Old Oct 13, 2011 | 04:42 PM
The clutch bearing replacement *IS* the cheap option. Doesn't require the system to be opened up, just a bearing replacement.
Old Oct 13, 2011 | 08:15 PM
pettyfog's Avatar
Ditto.
The thing is it requires special tools {may rent from Autozone 'free} to remove and may be a little more difficult given the bearing spun.
But I would definitely check out the option. It's what I would do and I have all the AC service tools.
And that belt for 'w/o' is meant for the factory ac delete pulley.
Buddykitchen
Dec 10, 2016 06:37 PM
g_mike
Aug 22, 2010 02:46 PM
nicocide
Jul 13, 2010 07:57 PM
keifer56
Jan 24, 2008 10:27 AM
drivemnutz
Jan 17, 2007 08:06 PM
