Envoy headlights on Blazer?
Old 06-13-2007 | 10:53 AM
Luca1Blazer's Avatar
Luca1Blazer is an unknown quantity at this point
Default Envoy headlights on Blazer?
I have a 2000 LT Blazer - would I be able to put HID headlights from an Envoy on my Blazer...or would it be less expensive and easier to by aftermarket HID headlights?
Thanks
Old 06-13-2007 | 11:23 AM
Default RE: Envoy headlights on Blazer?
I'm not sure if the radiator core support is the same between the Blazer and the Jimmy/Bravada of the same year, but if they are, you'd need a different grill, the headlights, the ballasts, and probably would want the assocaited wiring.
The problem with the aftermarket bulb upgrades to HIDs is that the stock housings were never designed for the arc orientation in a HID bulb. As such, the beam pattern will never be right and you probably won't have the proper cut-off for proper aiming. The beam pattern would most likely have strong and weak areas as well. You should get more light output...
Old 06-13-2007 | 11:55 AM
metalheadgoalie's Avatar
metalheadgoalie is an unknown quantity at this point
if u find envoy headlights i need one so let me know haha, my passenger side needs replacing
hollywoodgrad
01-25-2012 01:58 PM
dax44
06-08-2008 06:58 PM
megaroos_00
04-07-2008 05:56 PM
JBLAZE
04-02-2008 09:45 PM
jbeezy1983
01-04-2008 02:28 PM
Quick Reply: Envoy headlights on Blazer?
