Erratic fuel gauge 99 Blazer LT 4wd 4dr
Old Sep 20, 2007 | 11:26 PM
ForkliftJeff's Avatar
ForkliftJeff is an unknown quantity at this point
Default Erratic fuel gauge 99 Blazer LT 4wd 4dr
My fuel gauge is acting wierd. I know the gauge will move when cornering, accelerating or braking, but I could be parked on level ground with a quarter tank left and the gauge will go up to full then to 3/4 then full then half, so on and so on. Anyone heard of that happening?
Old Sep 21, 2007 | 06:48 AM
brock's Avatar
brock is an unknown quantity at this point
Default RE: Erratic fuel gauge 99 Blazer LT 4wd 4dr
Common problem with this generation of the blazer family. The sending unit (mounted on the fuel pump) has gone bad. Try driving by mileage until the pump needs replaced.
Old Sep 21, 2007 | 12:20 PM
soundguy's Avatar
soundguy is an unknown quantity at this point
yes, do a search first - tons on info on that subject. Good Luck - Mike
Old Sep 21, 2007 | 12:47 PM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
Mine does the same thing, but once you put it in drive it goes back to normal. I also hear (can't confirm) that our gas tanks lack baffles to control the gas moving around and it has something to do with it?
crazy fuel gauges ftmfl.
Old Sep 21, 2007 | 06:00 PM
I just bought this truck so I don't know how far a tank will take it. How many km's (or miles) are you guys getting per tank? According to the manual the 4dr holds 68L and the 2dr holds 72L.
Old Sep 21, 2007 | 07:21 PM
lemon blazer's Avatar
lemon blazer is an unknown quantity at this point
I average around 500-550km's per tank. I will always fill to the top and reset my trip meter and onboard computer to zero. I follow the onboard computer to tell me how many litres I've used.
Old Sep 24, 2007 | 05:30 PM
blazerboy124's Avatar
blazerboy124 is an unknown quantity at this point
i have the same problem, i usually go 250-300 Miles (sorry dont know the conversion for KM's) before i fill up, i know my tank isnt empty because it only takes like 15 gal. i have a 20 gal. tank...i get between 17 and 20 miles per gallon depending on if i beat it or not...hope that helps
MarkyMarc
17
Mar 8, 2013 08:25 PM
joonbugg82
Oct 28, 2012 08:07 AM
andyb731
Jan 3, 2012 10:16 AM
mtsumedi
Apr 10, 2011 04:49 PM
W2JGA
May 17, 2009 04:28 AM
