error codes 0128 and 0418
Old Mar 16, 2010 | 12:18 AM
dab18351's Avatar
dab18351 is on a distinguished road
Smile error codes 0128 and 0418
secondary air injection system relay A on a 01 blazer..where can i find it? and error code 0128 coolant thermostat coolant temp below thermostat regulating temp..does this mean i need to replace my thermostat? Thanks
p.s. Would these codes/problems also give me bad gas mileage? Thanks
Old Mar 16, 2010 | 07:52 AM
The thermostat code can definitely result in poor mileage. I would definitely consider a cooling system service with a replacement thermostat and radiator cap.
The relay is located behind the battery along with the fuse for the AIR system.
Old Mar 17, 2010 | 07:22 AM
dab18351's Avatar
Smile Thanks...
Thanks for your reply and i am going to replace both this weekend....Why would the coolant code give me bad mileage? as to the other code....Thanks for your help......
Dave
Old Mar 24, 2010 | 10:41 AM
dab18351's Avatar
Default code 0418
HI.....
Hopefully someone can help......I have a code 0418 (secondary air injection system Relay A circuit malfunction) I thought i found the relay next to the battery in the fender and i replaced it(AC Delco 158721) and i reset the codes and after a few it came back on again. Is this not the Relay A or was that relay B? Can someone give me a hand Thanks.....
Old Mar 24, 2010 | 10:57 AM
*Threads Merged*
I have attached the wiring schematic for your truck. You may want to test the wiring to the pump and solenoid.
Old Mar 25, 2010 | 08:40 AM
dab18351's Avatar
Any specific wiring to look at cause i am not to savy on wiring diagrahms? I did notice on the bottom underneath the battery tray that there was a terminal hook up that has a big power cable connected to it and the other end comes off of that to somethiong else and it might be corroded? Thanks
Old Mar 25, 2010 | 08:43 AM
All of the wiring runs from the relay location to the air pump under the radiator. Test continuity on all of the wires to their respective plug at the air pump.
abadinalbany
Apr 16, 2011 11:31 AM
HoleinOne350
Apr 6, 2011 10:40 PM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
