problems as always
Old Jan 20, 2010 | 01:07 PM
buddanicholson101's Avatar
buddanicholson101 is on a distinguished road
Default still havin troubles
well am still havin problems after doin the easy stuff and well now is throwin a P0300 code. and also threw a code for faulty coil wire. i would really appreciate someone helpn me out, especially now that i just found out my wife is pregnant and well i dont want it breakin down on her and the baby. thanks.
Old Jan 20, 2010 | 01:15 PM
kermit1112's Avatar
kermit1112 is on a distinguished road
what was the code for coil wire?
Old Jan 20, 2010 | 06:53 PM
bigjon1's Avatar
bigjon1 is an unknown quantity at this point
Search the code in the search feature, and there will be post that says "The dreaded P0300 code" I skimmed over it and it looks like it could be your o2 sensors or the spider assembly, check it out.
Old Jan 23, 2010 | 07:55 PM
aaron96gmc's Avatar
aaron96gmc is on a distinguished road
this sounded like a carbon copy of what mine was doing. pull the distributer and check the gear on it for wear. mine had alot of slack in the teeth causing the dreaded po 300 code. i changed the distributer and it has ran great eversence
Old Mar 10, 2010 | 12:38 PM
Default problems as always
its me again, well ive done all the cheaper routes and well lets say its slowly getting better. the other day my boss noticed that i didnt have a driverside brakelight, and well i tried changin the bulbs, wasnt them so i started to look at the fuses in the car and under the hood i had 2 that were blown under the hood so i replaced and drove home and well 90% of the hesitation was now gone but still no brake light on driverside and only hesitates when cold, or moisture is in the air and at high highway speeds like 70mph. so does any one have any ideas, and also what kind of muffler would give a nice beefy sound if i was going to upgrade that.
Old Mar 11, 2010 | 06:38 AM
redblzr4x4's Avatar
redblzr4x4 is on a distinguished road
Mine would hesitate too,it was the icm. As for the exhaust, you can't go wrong with a flowmaster 40 series.
Old Mar 25, 2010 | 09:56 AM
*Combining threads on the same topic from the same author* More of the story can be read towards the tail end of the Misfire and Stall, No Codes thread which goes back a ways...
Ok, lets get back to basics here. Please respond with a detailed description of the misfire/hesitation problem, a detailed list of what you have done to try to cure the problem (and why you chose to do each item on the list), and any other pertinent information you can supply (codes, etc). As always, please provide your vehicle information somewhere in your post requesting help!
Concerning the brake light problem, the bulb socket(s) could be corroded badly. Have a look down in the socket and see if you can clean up the contacts. Test with a test light for power when the headlights are on as well as when the turn signal is on or the brake pedal is pressed.
otter360
Aug 28, 2008 10:54 AM
98blazer12
Oct 10, 2006 11:20 PM
Philly Assassin
Jan 4, 2006 06:39 PM
oldsmobuick420
Nov 19, 2005 04:30 PM
swissmiss
Jul 10, 2005 01:16 AM
