EVAP system
Old Mar 13, 2013 | 06:06 PM
bassson's Avatar
bassson is on a distinguished road
Default EVAP system
hey all,
So I recently had an emissions test done on my car. The mechanic told me i needed a new evap canister so i to him to go ahead and do it so i could pass emissions.
After i got my blazer, my diagnostics tool is still giving me a fail, and my check engine light is still on.
So my question is, where is the evap canister/what is the easiest way to inspect it to make sure they actually replaced a part.
oh, and he lied to me because you only need to get 7/8 to pass emissions here in ontario.
Any help would be much appreciated
Its a 1998 chevy blazer
- Cheers
Old Mar 13, 2013 | 06:24 PM
richphotos's Avatar
left rear, near the fuel tank.
Old Mar 16, 2013 | 07:43 AM
Piski1982's Avatar
Piski1982 is on a distinguished road
Canister should be loacted in left rear of vehicle behind bumper cover. Thats where mine os and I have a 97. What Code dose it bring up when you scan it?
Old Mar 16, 2013 | 09:55 AM
El_Beautor's Avatar
If it's setting an evap code it could be as simple as needing a new gas cap. If the system senses a pressure leak anywhere it will throw the code. From what I've read online, it's rarely the charcoal canister that is the source of the problem unless you've somehow flooded it with fuel, or gotten water into it somehow.
It could also be the purge solenoid. Look for a small black box bolted to the cross member in front of your spare tire. It will have a vaccuum tube that goes to the fuel tank. It can get plugged with dust, mud, etc. and throw the code too. Unbolt it and clean it really good, then see if that fixes your problem.
Old Mar 18, 2013 | 06:29 PM
abig84's Avatar
at work when we replace emission controlled items we never clear the code. the truck has to do its drive cycle and shut it off itself. if you just clear it and go take it tested if the emission section "isnt ready" then it will fail.
but you would think they would inform you of that before you took your truck back
PaulS 1960
Jul 26, 2011 10:05 PM
Wayner1011
Feb 16, 2011 10:03 AM
Indianarocker
May 18, 2009 04:42 PM
turretman
Jan 21, 2009 06:19 AM
hebelracing38
Nov 2, 2008 04:13 PM
