Failed Inspection
Old 10-11-2007 | 10:22 PM
megtom2's Avatar
megtom2 is an unknown quantity at this point
Default Failed Inspection
Any advice as far as lowering hydrocarbons and Carbon monoxide?? My 1995 failed bigtime today and I have been cleaning my EGR and replacing my PCV. The O2 sensors will be next if I fail again in the morning then onto replacing the cat.
Anybody else had this problem and how did you resolve it?
Thanks
Old 10-11-2007 | 11:18 PM
rriddle3's Avatar
Default RE: Failed Inspection
I would suspect the cat would be the main culprit. When my old truck failed a test, I had to replace the cat to get the CO and NOx down to levels.
Old 10-12-2007 | 02:07 AM
Chevy Lover's Avatar
I would think that the O2 sensor could be the CO problem and the Cat could be the NOx....but...there are many possibilities.
If the coolant sensor is reading to cold then there is a request to richen the fuel supply, if you have a bad plug or wire or contaminated engine oil your NOx will be to high...in other words, it's hard to guess and be accurate.
Do you have any small vacuum leaks????
Old 10-13-2007 | 04:59 PM
megtom2's Avatar
After doing the plugs, pcv, egr and oxygen sensors I still failed miserably. Looks like another $120 to get a cat put on. Hopefully that will take care of it. No vacuum leaks.
Old 10-20-2007 | 05:36 PM
megtom2's Avatar
Passed today after changing out the plugs, plug wires, egr, O2 sensors and the cat. It cost me $300 to make Al Gore happy. No biggie since the truck now runs like ti did 10 years ago.
Old 10-20-2007 | 05:52 PM
BigGreenMonster's Avatar
BigGreenMonster is an unknown quantity at this point
If you want to make Al Gore happy, you have to junk your blazer, ride a bike and use one square of toilet paper the rest of your life.
Or you could just buy a Toyota Prius, even though they do more harm to the environment than driving a Hummer.
Old 10-20-2007 | 06:45 PM
thegr81's Avatar
aint that the truth al gore can go @#$@@$ and some lol sorry ex military didn't care for al gore or the bush administration
madblazerowner
02-15-2012 04:50 PM
Benedict1337
85
07-18-2010 01:18 AM
woodsballr
03-13-2009 01:10 PM
Spartan66
07-03-2008 01:11 PM
Blahman20
04-21-2007 08:06 AM
Quick Reply: Failed Inspection
