failing smog check p0466 code
![Question](https://blazerforum.com/forum/images/icons/icon5.gif)
I have a problem trying to pass smog. I pulled the code p0466 which i found out is a clogged canister vent solenoid. I have a 01' blazer 4 dr, 4x4,. i had check the vent solenoid that is next to the spare and had a little dust but nothing major tried my best to blow it all out checked lines coming from charcoal canister all clear again blew some air in cannister and a lot of dust came out. btw i had lost gas cap for a week it has been replaced since Is there something i am missing or is there a way to test the vent solenoid? Could it be something with the gas tank?
THankz for the response but i had already had search google that is what had led
me here
me here
I read you can xheck if the solenoid by applying 12 v how would i do that and, if i disconnect the plug while the car is running should i hear anything
Correction on the code it p0446
WoW thanks again this is some great info i will start doing a deeper inveatigation today after work. And pick up a vacuum at the auto shop on my way. I have suspicion it might do something with my fuel pump because my gauge is always empty but that could be a whole other reason.
![Talking](https://blazerforum.com/forum/images/icons/icon10.gif)
Well after a hard time finding a vacuum and after all my diag. I found my vent solenoid was no good replaced it clear code and driven 100 miles code as not been seen since. Thanks for the helpull advice your great
The worst way to learn is to ask for the fish to be handed to you.
It's a win-win. I assemble knowledge on the fail, meaning I learn, too. And you get more confidence in your own troubleshooting abilities.
And neither of us chances coming out looking dumb.
- and I HOPE you caught on to my search methods. A GOOD search skill can find anything, with patience.
![Smile](https://blazerforum.com/forum/images/smilies/smile.gif)
Gear Grinder
01-29-2011 12:41 PM
Drivin_Foxfire
10-18-2009 06:14 PM
