Fan
Old Apr 25, 2008 | 05:46 PM
noom14921992's Avatar
noom14921992 is an unknown quantity at this point
Default Fan
how to replace the engine fan. i got a used one and it took 30 seconds for them to get it off. is it the same to put it on.they used a special tool do i have to buy bot one or what?
Old Apr 25, 2008 | 07:14 PM
Default RE: Fan
and do i have to put the gard back on to make it run good?
Old Apr 25, 2008 | 07:15 PM
johnnyr's Avatar
johnnyr is an unknown quantity at this point
Default RE: Fan
Talk about coincidence... I just came in to ask that same question. I just got an electric fan and I'm not sure how to take the old fan off.
Old Apr 25, 2008 | 07:34 PM
Default RE: Fan
i hope some one tells us how to do it
Old Apr 25, 2008 | 08:19 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: Fan
I believe there are a few post on here that talk about the fans removal. If I recall you either need to get the special fan tool or you have to make it out of steel yourself. If you don't have a welder you probably need to buy it or find a local place that has one to lend.
Old Apr 25, 2008 | 09:24 PM
WolfPack's Avatar
Default RE: Fan
Or a very large adjustable cresent wrench will do if i'm not mistaken. The problem is it's like a 2' across bolt...but I could be mistaken.
Old Apr 25, 2008 | 11:02 PM
johnnyr's Avatar
Default RE: Fan
https://blazerforum.com/m_88212/tm.htm
Yep, this is a good post on removing the fan. I hope my wrench is big enough! I'll give it a try in the morning.
Old Apr 26, 2008 | 11:23 AM
portcqb's Avatar
Default RE: Fan
Yah if you dont have the tools advanced auto or other auto parts stores might have one you can use.
Old Apr 26, 2008 | 11:19 PM
johnnyr's Avatar
Default RE: Fan
I used **what else**? water pump pliers, lol. Once the nut breaks loose it spins right off. At least mine did.
Thanks for the replies!
Old Apr 27, 2008 | 02:23 AM
guywm25's Avatar
guywm25 is an unknown quantity at this point
Default RE: Fan
the nut on my fan was a 36mm and made one myself out of steel otherwise some parts stores have a loan-a-tool policy and ask for the clutch fan assembly wrenches
gitch93
Jul 23, 2013 08:06 AM
cheesequaker
Apr 25, 2012 01:44 PM
85kulan
Oct 4, 2011 09:51 AM
valeria1782
Jan 24, 2011 04:12 AM
upblazer95
Nov 16, 2008 03:20 AM
