Fan blower motor
Old Nov 7, 2012 | 05:26 PM
Spiderman's Avatar
Spiderman is on a distinguished road
Default Fan blower motor
Hi everyone,
I have a 99 Blazer 4.3 with A/C and in the last couple of weeks the fan motor has been making a "squawking" sound when it's turned on.The sound kind of comes and goes.Turning it off and then back on will sometimes make it stop,but not always.I was wondering how hard it was to replace the fan motor and if there were any tips on how to do it.
Any advice would be greatly appreciated.
Thanks,Spiderman
Old Nov 7, 2012 | 06:23 PM
abig84's Avatar
it will be under the hood on the passenger side by the firewall there will be like 5 hex head screws holding it on. the biggest headache is the bottom bolt is really hard to get at. may need really small hands or the proper way is to remove the wheelwell but thats not always possible due to rusty bolts.
but other then that stupid screw its pretty easy.
Old Nov 7, 2012 | 06:57 PM
Might be on that one that you have to cut the black plastic housing before you can even see the bolts. Usually it's molded into the housing "cut here for service". Use a utility knife and be careful, the piece you cut out needs to be put back on. Probably have to remove the PCM and coolant reservoir to get the motor out. As mentioned, a couple of the bolts are "neatly tucked out of the way"
Old Nov 7, 2012 | 08:32 PM
Irocz327's Avatar
Irocz327 will become famous soon enough
If its starting the do "turkey calls" then fix it now! I'm started doing only when it was cold so I put it off & soon it started doing it all the time & then ur debating if you wonna listen to the turkey or freeze ur *** off lol
Old Nov 7, 2012 | 10:26 PM
rriddle3's Avatar
Originally Posted by Captain Hook
Might be on that one that you have to cut the black plastic housing before you can even see the bolts. Usually it's molded into the housing "cut here for service". Use a utility knife and be careful, the piece you cut out needs to be put back on....
Seal it back on with a bead of black RTV.
Old Nov 8, 2012 | 03:19 PM
Spiderman's Avatar
Thanks to everyone for the great advice.I'll try to get to it this weekend.What exactly is black "RTV"?I've never heard of that before.Are there any u-tube videos of this job?
Thanks again for the help,much appreciated.
Spiderman
Old Nov 8, 2012 | 07:02 PM
RTV is a sealant that comes in a tube, smells like bathtub caulk most auto parts stores have it. Search you tube, might be video on how to replace the blower.
Old Nov 8, 2012 | 08:19 PM
spittybays
Guest
Posts: n/a
Room Temperature Vulcanizing aka silicone sealant aka black Permatex
Old Nov 11, 2012 | 08:04 AM
Spiderman's Avatar
Spiderman here,
I will be changing the fan motor at a friends place,he has a heated garage,but he hasn't got any tools what so ever.Does anyone know exactly what tools I need to do this swap out so that I can make sure that I take what I need to his house because it on the other side of town.Any help on this would be much apperciated.
Spidermsn
maxvamp
Oct 31, 2020 08:19 AM
JFD444
Dec 5, 2011 01:02 PM
aztcwrior25otvws25
Apr 23, 2011 12:12 AM
daniel010
Jan 25, 2009 11:40 PM
motorhead0406
Apr 17, 2007 09:37 AM
