Fan for heater and air quit working
Old Dec 14, 2007 | 05:01 PM
ktallman's Avatar
ktallman is an unknown quantity at this point
Default Fan for heater and air quit working
My fan for the heater and air just quit working. It worked about an hour ago when I went to town, but on the way home I tried it and it doesn't work. I checked all the fuses and they are all good. I am at a loss as to what to look for.
Old Dec 14, 2007 | 05:27 PM
Default RE: Fan for heater and air quit working
Does it work on any of the fan speeds or are they all dead?
Old Dec 14, 2007 | 10:34 PM
ktallman's Avatar
All fan speeds are dead. I have a 2001 2dr 4wd Blazer.
Old Dec 15, 2007 | 02:24 PM
AJBert's Avatar
The three lower speeds work off a fuse and high works off a relay. Looks to me you may need a new motor.
Old Dec 15, 2007 | 02:31 PM
gtseater's Avatar
gtseater is an unknown quantity at this point
Sounds like the fan motor has gone out . The fan motor is under the hood on the Cowl (PASS ) side . Pull the plug out and hook a hot wire up to it (motor) and a ground to the motor and see if it will work .
Old Dec 15, 2007 | 09:17 PM
ktallman's Avatar
I think I found the problem. I was checking things out and bumped the wiring harness to the switches and it started working. It quit again and I did the same thing and it started working again. So I think I got it narrowed down to where the problem is.
Thanks to all that replied.
Old Dec 16, 2007 | 08:01 AM
You moved the connections at the back of the control head in the truck? If so, you may have some cold solders on the circuit board. If you can, pop the control head apart and just reflow the solder on the pins that connect to the wiring harness.
jeffery57
Mar 9, 2016 01:30 PM
Mike F in Nebraska
Aug 2, 2014 06:25 PM
mjw1991
Feb 24, 2013 10:18 PM
bowtie-72
Feb 19, 2012 10:36 PM
pndurbin
Jan 15, 2008 10:18 AM
