Fast Turn Signal After Replacing Bulbs & Flasher
Old Jan 13, 2018 | 07:34 PM
rivercityjon's Avatar
rivercityjon is on a distinguished road
Default Fast Turn Signal After Replacing Bulbs & Flasher
Hi,
I've scoured the forum and can't find anything applicable...
- 2005 Blazer ZR2
- Drivers side front and rear bulbs blink fast with turn signal but normal with hazards
- Have replaced both front drivers side turn signal bulbs and drivers side rear turn signal bulb
- Have replaced flasher in behind glove box
Is there another flasher elsewhere? Or something else that I should check?
Old Jan 14, 2018 | 12:21 AM
odat's Avatar
Check all bulbs on the drivers side including small clearance lights.
Check all driver side light grounds and sockets for broken or loose wires, corrosion Ect.
With hazards on the riders side ties together with driver side and will compensate for the fault
Old Jan 14, 2018 | 02:22 PM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
I had a similar situation with the right turn signal, replaced the bulb in the rear and all was well for a while then it occurred again. I had a cracked lens that allowed rain water to get to the bulb socket and short the circuit. replaced lens and no more problems.
Old Jan 15, 2018 | 01:23 AM
Most vehicles have a separate circuit for the hazard flasher by design.
It is kind of a redundant design. The hazard flasher has it's own power supply, mostly directly on a always hot battery wiring and it's own flasher relay.
While the turn signals are hooked up in such a way that when a bulb fails it cuts on the time needed to do a cycle. Could be anything from the bulb, to 2004 Blazers's corrosion problem to a ground problem.
patty benoit
Jun 27, 2011 04:22 PM
medway creek
Nov 5, 2009 08:49 AM
kbreck
Jul 11, 2008 07:43 PM
syrblitz19
Jun 10, 2006 02:27 AM
kccapt
Nov 23, 2005 01:34 AM
