first time working on blazer
Old Jun 5, 2012 | 12:14 AM
kyboy's Avatar
kyboy is on a distinguished road
Default first time working on blazer
my brother in law is bad shape got hurt at work bad his wife sleep at the hospital for weeks he still there now truck broke down there would not start she told me this has been going on for along time i put a little gas down her and she started right up did run ok next morning same thing put fuel gauge on it pre start 60psi im thanking good at run 57psi good tap it psi goes up also good turn the truck of psi goes up 65 psi 1/2 hr 60 psi 2hr 50 so on so on and then the hard start by morning no start. im thanking reg. is bad just would love some in out on this and some hints on things to do when im in there.please help im lost
Old Jun 5, 2012 | 01:10 AM
50lb_cat's Avatar
What year? When running the fuel pressure and leakdown test its key on engine off. Key on should be around 55 psi and shouldn't leak down. If I'm reading it right, it doesn't sound like a fuel problem. Could be bad distributor cap and rotor or ignition coil. But post back the key on, engine off numbers and how much leak down there is.
Old Jun 5, 2012 | 01:31 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
So are you saying it starts fine sometimes and then sometimes it wont start at all?
Old Jun 5, 2012 | 01:34 AM
50lb_cat's Avatar
+1, kind of confused lol
Old Jun 5, 2012 | 07:34 AM
kyboy's Avatar
2000 blazer extreme 4.3 v tech .it bleeds off to about 20 to 30 pis over night and is always hard to start in the morn sometimes it will not start at all. have to put gas down her to get her to start. up late last night guys. that was the end of a 26 hr work day lol.i have the upper intake almost off thanking purser reg is bad . but did not thank about the cap and button. good tip so what do you guys thank
Old Jun 5, 2012 | 07:48 AM
kyboy's Avatar
key on 61psi let it there for 30min 45 to 30psi.
kyboy's Avatar
Old Jun 5, 2012 | 11:31 AM
50lb_cat's Avatar
How much drop is there in the first 10 minutes? While you have the upper off, look at the passenger side of it. Is it really clean and can you see signs of washing? If you have a leaking regulator or injector then the passenger side will look really clean. It should be kind of dirty looking and kind of copper in color.
Puscypher
Apr 1, 2014 11:43 AM
Willmsy
Mar 11, 2013 02:50 PM
Silver00LT
Sep 14, 2010 10:33 PM
Silver00LT
Sep 13, 2010 09:52 AM
77Nova
Aug 28, 2010 10:38 AM
