Flasher always ticking
Old Nov 19, 2010 | 09:42 AM
blazinloud's Avatar
Default Flasher always ticking
I noticed my flasher ticks by itself alot more often when it gets cold out. but somehow when i apply the brakes it stops.
playing with the signal lever dosent change what it does, just ticks constantly and stops when you touch the brake pedal.
98 jimmy
Old Nov 19, 2010 | 09:53 AM
Very common problem. Try messing with your hazard switch to see if it stops. If it doesn't, try replacing just the hazard switch per the DIY articles in the Tech Article (DIY) section (see index link in my sig). If that still doesn't work, the whole multifunction switch is at fault.
One thing you may want to do first is check with the GM dealer to see if the recall applies to your VIN. If it does, let them fix it!
Old Nov 19, 2010 | 10:00 AM
blazinloud's Avatar
ok, thank you, ill try messing with the hazzard switch
medway creek
Nov 5, 2009 08:49 AM
Cooligan
Nov 12, 2007 11:44 AM
apekim
Sep 15, 2007 10:46 AM
syrblitz19
Jun 10, 2006 02:27 AM
kccapt
Nov 23, 2005 01:34 AM
