Floor/Defrost door problems
Old Feb 7, 2014 | 12:03 PM
Krazymexikn's Avatar
Krazymexikn is on a distinguished road
Default Floor/Defrost door problems
I have a 2000 Chevy Blazer and the floor heat doesn't work, I found out that whatever happened the door, that controls heat to the floor, defrost and blends, was stuck down so all I can get is defrost. Is there a way to remove that door (without taking the dash off) or does anyone have a method they've used to hold the door in the middle so I get both?
Old Feb 8, 2014 | 03:29 AM
LannyL81's Avatar
The air flow is controlled through a series of vacuum operated actuators and sounds like one of them has failed or the rotary vacuum switch in the control panel has failed.
I believe you should be able to reach the actuator by just removing the lower trim panels, but will likely need to remove the center console as well. There are three lower trim panels across the dash and I seem to remember that the driver's panel has to come off first to expose one screw for the center; the far right side can stay (doing this from memory...and it has been awhile since I have done this.)
Once the trim panels are off you can test the actuator to find-out if it has failed or there is no vacuum going to it. Now I do not remember if the dash has to come out to replace the actuator or not...been too long ago. But you will be able to determine what the problem is.
Good luck and let us know what you find.
Old Feb 8, 2014 | 05:52 AM
Pewter2002's Avatar
Pewter2002 is on a distinguished road
My 2002 did the same thing. In my case, that door broke the hinge tabs off and the Dealer charged over $700.00 to pull the dash and heater box and replace the door. Yours could be something else, tho. If you search the forum, someone cut the heater box open and replaced the door without pulling the dash. Good luck.
Old Sep 6, 2021 | 09:02 AM
hdmacs's Avatar
hdmacs is on a distinguished road
Hello
I have a 2001 2 Door Blazer
I was wondering if anyone knows how to remove how HVAC Defrost Mode Door Actuator 2001 blazer?
I have replaced all vacuum lines under hood back to transfer case switch. I noticed the actuator is not pushing all the way out and has slop to it.
please help before I break something
specialty8
29
Jan 24, 2023 10:35 AM
v8449
Mar 29, 2021 09:13 AM
Vahomboy
Dec 29, 2014 09:06 AM
mjr45
Nov 13, 2014 07:53 AM
chrissy
Dec 4, 2006 03:23 AM
