flushed dexcool, water pump?
Old Dec 13, 2009 | 12:51 PM
bmxican1023's Avatar
bmxican1023 is on a distinguished road
Default flushed dexcool, water pump?
Hi all, long time lurker, first time poster.
I recently flushed the cooling system in my 00 4x4 blazer, took out the dex cool and put in the green stuff, I also replaced the thermostat. About two to three days after I finished the flush, I started leaking heavy amounts of coolant while parked on my driveway. It looked like the coolant was coming from the water pump. I was wondering if flushing the dex cool and putting in the green stuff would cause the water pump to fail? or if it is just a gasket? The truck has 190k and I do not know if the water pump has ever been replaced before. Any suggestions/tips/etc would be appreciated.
Old Dec 13, 2009 | 03:42 PM
rriddle3's Avatar
The change of coolant would have no effect on the pump. I think it's just coincidence.
Old Dec 13, 2009 | 04:57 PM
ah ok thanks, I heard that dex cool was used cause it helped dissipate heat more efficiently and that it also lubricated parts (such as the water pump) and that since the water pump lost that lubrication that it went bad. I already bought a new one and gotta replace it regardless, I just wanted to know if the flush had anything to do with it.
Old Dec 14, 2009 | 07:20 AM
jstein's Avatar
jstein is an unknown quantity at this point
I recently made the switch to the green stuff. The engine was throwing a code that lead me to a failed thermostat. Replaced that and added the green and its worked beautifully since.
Old Dec 14, 2009 | 10:10 AM
Bob_55's Avatar
Bob_55 is on a distinguished road
Flushed all our vehicles out starting in 2002 after replacing countless intake manifold gaskets & water pumps. Some vehicles were so caked-up, we couldn't drain the system through the radiator drain. We replaced (after flushing the system 5x) with green antifreeze. Never have replaced an intake manifold gasket or water pump since! These are company fleet vehicles, friends,family,& my own personal vehicles which we all still drive today. Thankfully i have a good friend that owns a radiator shop!
*3- s10 4wd Blazers (96,2-98's)
*4 - Bonnevilles (2-97's,2-99's)
*2 - Malibu's (2000)
*1 - Impala (2001)
*2 - Sierra's (98,99)
*1 - Silverado (2001)
*2 -Express vans (99,2000)
Also, I'm sure someone posted this before, but a few of you newbies may have missed it.......
http://www.petitiononline.com/mod_pe...d.cgi?GMcnsmrs
Old Dec 14, 2009 | 10:16 AM
Ok, we have a thread devoted to this debate. READ through that ENTIRE thread and then post your "opinion" of what the issue is. No need to drag more threads down this rabbit hole. Besides, that petition doesn't have much to do with Dexcool...
Old Dec 15, 2009 | 02:12 PM
Sorry I wasn't trying to spark up the debate, I was just trying to figure out if the flush caused the water pump to fail. I already replaced it (thanks to ravenhurst's tutorial here) and it doesn't leak and everything seems to be working fine.
ps. swartllk - You can lock this thread before it becomes a flame war if you want.
Old Dec 15, 2009 | 02:18 PM
rriddle3's Avatar
Glad you got it fixed. Seems like I have been snake bit by water pumps on cars all my life!
I don't think Kyle's post was directed toward you. You had a legitimate question.
Katmandu
Jan 14, 2010 02:10 AM
blazerboy30
13
Jul 21, 2009 01:19 PM
2blzers
Dec 16, 2007 10:14 AM
woodsballr
Jan 28, 2007 07:17 PM
magnum434
Engine & Internal
Aug 11, 2006 09:56 AM
