front axle stuck
Old Jul 11, 2015 | 01:09 PM
Tajohns34's Avatar
Default front axle stuck
I am trying to replace the left front axle in my 2000 blazer. I got everythng apart put the axle shaft will not release from the front differential. I have pried, hammered, pulled with vice grips, pulled some more, pried and hammered more. I have spend about 3 hours trying to get it out. Is there some trick to getting this thing to release? I have already given up and am getting ready to put it back together and take it to a shop. Any help would be appreciated.
Old Jul 11, 2015 | 01:44 PM
AJBert's Avatar
Block of wood and a BFH usually does the trick.
Old Jul 11, 2015 | 02:06 PM
Tajohns34's Avatar
I tried that but I can't get wood behind it.
Old Jul 11, 2015 | 08:42 PM
Tajohns34's Avatar
I finally gave up on it. I will have to take it to a shop. I have never had an axle get stuck like that.
Old Jul 12, 2015 | 04:09 PM
LannyL81's Avatar
I got the axle out of my '02 by using a large...LARGE screwdriver and pryed between axle and differential...careful not to pry against the grease seal. Came out in within a minute.
Right side is quite different though with that tube....but it came out as well.
Old Jul 13, 2015 | 09:32 AM
Tajohns34's Avatar
I did the right side last year and it came right out. This left one is not coming out. I used 3 different pry bars and a giant screw driver with no luck. I am just going to have to either take it to a shop or find someone to get it out for me.
Old Jul 13, 2015 | 09:35 PM
Here is the correct set up for the job. The slide hammer and axle adapter are available in the loaner tool program. Usually one good whack will remove the axle.
OEM/Slide hammer with 18 threads 27033 at AutoZone.com - 2 reviews
OEM/FWD axle puller adapter 27058 at AutoZone.com - 5 reviews
Old Jul 14, 2015 | 07:06 AM
Tajohns34's Avatar
Awesome! I will have to give that a try the next time I have a day off.
Old Jul 17, 2015 | 07:37 PM
Tajohns34's Avatar
It worked! Thanks captain hook!
Old Jul 17, 2015 | 08:34 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
The Captain does it again!
chowell
Mar 6, 2021 09:47 PM
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
blajeans
Jan 9, 2013 12:58 PM
Havensk
Jul 25, 2010 08:16 PM
