front diff seals
Old Nov 5, 2013 | 01:35 PM
Double d's Avatar
Double d is on a distinguished road
Default front diff seals
hey guys great page here im new to the blazer I just bought a 1999 ls and I need to do some seals in the front diff I need to do the front pinioin seal and a right front axel has any one got a procedure or some exploded diagrams so I can make sure I bought the right seals,the parts store said they were the same ,but I just wanna double check ,, thanks dwayne
Old Nov 5, 2013 | 08:15 PM
Zanders's Avatar
Zanders is on a distinguished road
Truck Parts and Truck Accessories
^exploded view
https://blazerforum.com/forum/tech-a...removal-23866/
^removal of cv shaft, u will see the seal then.
A chilton manual would be plenty sufficient for these jobs.
Tips:
Haven't done the pinion seals, only the axle shaft seals up front. But as for the right axle shaft seal, I took the whole shaft and carrier tube out of the differential because with the shaft still in the tube I couldn't pry out the seal. Careful when doing this because on the differential side of the shaft there are a bunch of washers and gears the will fall off TAKE PICS OF THEM BEFORE DIS-ASSEMBLY. The only issue I had was re installing the cv shaft (mine are the slip in variant) in order for the splines to match up I had to remove the shocks lower bolt and slide her(the shock) to the right to make room for the cv shaft.
Old Nov 6, 2013 | 02:17 PM
abig84's Avatar
usually when i do pinion seals when removing the yolk off the differencial make sure you mark it so you re install it exactly where it was when you put it back on. i usually take a cut off whell and actually grind a small notch into the threaded part then on the yolk, and to be extra paranoid take a few pictures of it too so you dont forget how far down it was. i hate using markers cause sometimes they can wipe off
Old Nov 6, 2013 | 06:17 PM
Double d's Avatar
thanks guys .appreciate the advice...
Bobcat13
Aug 31, 2014 06:38 PM
benthm7
Dec 25, 2012 04:25 PM
bertrenolds
Nov 7, 2012 03:05 PM
bvanfossen
Aug 2, 2011 09:53 PM
Mapoftazifosho
Oct 26, 2007 10:26 AM
