Front Diff Seals
Old Jul 29, 2011 | 10:06 PM
bvanfossen's Avatar
bvanfossen is on a distinguished road
Default Front Diff Seals
Well I drove to work and my front drivers side is leaking so bad I'm not going to drive it until it's fixed.
2000 Blazer ZR2
There is a little play where the cv's come out of the axle housing- is this normal? Or is this what caused the seals to wear and leak?
Any help is appreciated
Thanks
Old Jul 31, 2011 | 09:19 AM
bvanfossen's Avatar
I can move the CV at the knuckle closest to the diff a 1/4" up, down, side to side, etc.. On both sides. I'm thinking this is normal.
Can anyone confirm this please?
Thank You for the help
Old Aug 1, 2011 | 10:33 AM
bvanfossen's Avatar
Exclamation
I have to fix the truck on Weds so it's drivable.
Someone must have an idea- I certainly don't.
I don't know if the play is normal or if It's going to cause the seal to go back out.
Anyone?
Old Aug 1, 2011 | 10:51 AM
There should be next to no up/down/front/back play where the CV shaft enters the front axle on either side. If there is play, the bearing inside has failed.
BTW, please include your vehicle information in your post, or better yet in your signature or create a garage which will put the details under your screen name.
Old Aug 2, 2011 | 09:29 AM
bvanfossen's Avatar
Do you think the front Differential will need to be pulled apart?
I'm also assuming the CV joints are bad- right?
I see #4 for the passenger side. I don't see the bearing for the drivers...
Thanks a million for your help-
Old Aug 2, 2011 | 10:34 AM
The bearing is #52 on the driver side. The seal is #50.
Old Aug 2, 2011 | 09:53 PM
bvanfossen's Avatar
will the diff have to be split to get to #50?
What are those bearings called?
Tryting to figure out if I can do it or not-
Bobcat13
Aug 31, 2014 06:38 PM
Double d
Nov 6, 2013 06:17 PM
benthm7
Dec 25, 2012 04:25 PM
bertrenolds
Nov 7, 2012 03:05 PM
Mapoftazifosho
Oct 26, 2007 10:26 AM
