Front Drivers Side Door Hinge
Old Oct 15, 2013 | 08:14 PM
HostileJava's Avatar
HostileJava is on a distinguished road
Default Front Drivers Side Door Hinge
Ok, so I've seen a few threads on here where the hinge pins on the doors need to be replaced along with the bushings, I know my drivers side needs it and I haven't gotten to it yet. However tonight I opened the door heard a loud snap and looked at the hinge to find that the inner pin(closest to the body) had broken and let the spring loose that rides on the lower piece. I removed the lower part that broke off and the spring and the door still seems to function pretty normally. I know I can get the main hinge pine replacement but does anyone know where to get the replacement pin that is closest the body of the truck?
Attached Thumbnails Front Drivers Side Door Hinge-imag1019%25255b1%25255d.jpg
Old Oct 15, 2013 | 09:17 PM
Ok, I did some digging and the closest part I can find is this:
1999-2000 GMC Yukon Door Hinge Roller Pin for Front Upper at 1AAuto.com
Does anyone know if this would be the correct replacement?
Old Oct 15, 2013 | 09:29 PM
hans109h's Avatar
hans109h is on a distinguished road
I don't think that is going to work for you, YRMV.
I think you need to replace your entire upper hinge at this point. Check rockauto.com.
Hans
Old Oct 15, 2013 | 09:39 PM
Hans
The pin seems to have just snapped in half and seems to be threaded in at the top, I can't imagine I would have to replace the entire hinge, worst case I'll get one from the junkyard but I was hoping to find the part new. Anybody?
Old Oct 16, 2013 | 09:23 PM
gitch93's Avatar
gitch93 is on a distinguished road
i have the same issue on mine but haven't botherd replacing it as the hinge is welded to the body and im not going through the hassle of that
Old Oct 16, 2013 | 11:28 PM
burned's Avatar
burned is on a distinguished road
I got mine at a dealer. You have to grind the top part and then punch it out.
The new one will have to be tack welded into place at the top. Be sure to paint the new one before installing. Comes as 2 pieces.
BTW the hinges on these vehicles are glued not welded to the body
Old Oct 17, 2013 | 12:51 PM
abig84's Avatar
yeah my fullsize has the same issue. it just sucks cause the door doesnt stay open when letting it go but yeah, ive actually changed the welded on hinges on a 95 fullsize and it sucks. i dont know if s10s are the same way but the fullsize had 4 spot welds in the middle of the hinges that had to be drilled out. and the dimples werent in the right place. took hours or drilling to get them off.
if it was me and its that big of a deal, replace the entire door lol. i will never do one of those hinges again
Old Oct 17, 2013 | 09:01 PM
burned's Avatar
Here is a walk through on how to fix your problem:
Replacing hinge detent roller
Its not that hard to do!
Old Oct 18, 2013 | 07:11 AM
I'll have to get a better picture of mine and actually try to spin the top half out but on mine it looks like it's just threaded in on the top not welded.
upmaine
Jul 9, 2012 12:31 PM
blanco36
Mar 6, 2012 01:14 PM
Wexinlo
Apr 6, 2011 11:35 PM
celchlepp
Sep 9, 2010 02:24 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
