front end loose?? Wobbles at 65 +???
Old Feb 19, 2008 | 10:19 PM
jdpilot's Avatar
jdpilot is an unknown quantity at this point
Default front end loose?? Wobbles at 65 +???
97 ls 4x4. New ball joints as of 10k ago. So I am sure it is not them. truck has 205k and runs strong!! The trucks front shimmys at high speed and she is starting to eat tires. Anything over 65 and she jiggles like hell. The outer egde of the front tires is starting to cup. Jacked it up and heres what I found. Holding the tire at 12 and 6 o'clock, trying to jiggle up and down (ball joint test) and she is firm. However, holding the tire at 3 and 9 o clock and there is massive play and wobble. Even when someone is holdingthe steering wheel tight. What is this????????Tie rods look ok.....help
Old Feb 19, 2008 | 10:20 PM
cliro's Avatar
cliro is an unknown quantity at this point
Default RE: front end loose?? Wobbles at 65 +???
wheel bearings are shot.
Old Feb 20, 2008 | 12:21 AM
WolfPack's Avatar
Get em fixed quick! You could lose a wheel!!
Old Feb 20, 2008 | 01:32 AM
thegr81's Avatar
I agree with wheel bearings! Get them changed before you drive it anymore!!!
Old Feb 20, 2008 | 06:24 AM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
I say Centerlink and tierods!! Mine went bad in my 2002 already.. 2wd also check the idler arm... lay under the truck without it being jacked up grab onto the idler arm and try and push up and down it shouldnt move...
Old Feb 24, 2008 | 07:14 PM
Sorell's Avatar
Sorell is an unknown quantity at this point
Once you get those replaced, get your wheels balanced too. If you lost a wheel weight you'd get that wobble without any front end damage normally from 90Km/h and up
Old Feb 24, 2008 | 09:01 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Idler arm, possibly pitman arm, double check the tie rod ends, with that kinda miles they could be worn. And I doubt the wheel bearings are bad, they would usually have a noise with them, and they would have the movement at the 12 and 6 wobble test. The idle arms on these trucks are very, very common, and go out quite often. Good luck, HTH.
Old Feb 24, 2008 | 09:57 PM
HeyYou's Avatar
HeyYou is an unknown quantity at this point
Have a friend do the wobbling, while you look to see where the slop is. You can do this with the steering column locked, (Key out..) and you will be able to pinpoint what parts are giving you the problem.
schollianmj
Aug 16, 2015 11:37 PM
schollianmj
Mar 5, 2012 08:03 PM
Tinted
Feb 7, 2011 01:11 PM
OS1FIX
Aug 19, 2009 04:12 PM
rastaskater
Feb 27, 2008 09:16 PM
