Front end noise
Old Feb 3, 2010 | 10:46 PM
Tbanditt's Avatar
Tbanditt is on a distinguished road
Default Front end noise
I'm getting a grinding noise as I drive. Turn the steering wheel makes it go until it's back to straight. Any ideas?
Old Feb 4, 2010 | 05:14 AM
nj4x4blaze's Avatar
hub bearing could be shot.
Old Feb 4, 2010 | 07:01 AM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
x2 on wheel bearing, jack the front up, and push at 12' clock and pull at 6, on the tire, let us know if you have any movement, could be balljoints, tie rod, etc. even struts if they're bad enough
Old Feb 6, 2010 | 12:18 AM
simman22's Avatar
simman22 is on a distinguished road
i have the same noise...i tried lifting the front end and moving the tires and they are tight...mine also goes away when i turn to the right. it is there when the wheels are forward and turned to the right.
Old Feb 6, 2010 | 01:09 AM
toaks1's Avatar
toaks1 is on a distinguished road
are u running 4 wheel drive on dry pavement?
Old Feb 6, 2010 | 02:01 PM
wireman's Avatar
wireman is on a distinguished road
Wheel bearing hub...... mine was making a loud road noise, jacked up the front end and not much movement at all but I have an uncle that is a mechanic and he said he's positive that if I change the hub my noise will disappear. I went to the salvage yard to pick one up (lot cheaper than $150 if its not the problem) and changed it and guess what.......
Old Feb 7, 2010 | 11:50 AM
simman22's Avatar
thanks for the information man...i greased every fitting and it is still there. it really sounds like something is rubbing but nothing obviously is. i will change the hub and give an update if it fixed it.
Old Feb 7, 2010 | 04:49 PM
pink63impala's Avatar
pink63impala is on a distinguished road
would a hub bearing make a thump* thump* thump* noise?. mine doesnt make a constant roar like a bearing,but i can hear a thump sound about everytime the wheel makes a revolution.and gets worse when turning
Old Feb 7, 2010 | 04:55 PM
Banned
yeah also a grinding noise if its bad enough.
Old Feb 7, 2010 | 05:03 PM
oh joy!
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
Chrismacster
Apr 2, 2009 06:57 PM
desertirish
16
Mar 28, 2007 08:01 PM
kwsrv@libcom.com
Sep 7, 2005 05:01 AM
