Front end squat
Old Mar 26, 2009 | 05:23 PM
blazer84660's Avatar
blazer84660 is on a distinguished road
Default Front end squat
I just replaced my shocks on the front because they were bad with some KYB GR-2 due to budget restriction, on my 97 blazer and it still seems to be squatting the same amount. What is the problem and what can I do to resolve it? I also changed out the sway bar bushings.
Attached Thumbnails Front end squat-truck-002.jpg   Front end squat-truck-001.jpg
Old Mar 26, 2009 | 05:47 PM
Swain's Avatar
Swain is an unknown quantity at this point
Need more info on your truck...is it 4wd? If so the torsion bars are sagging, you can crank them up a bit but the problem will come back and new torsion bars are quite pricey! They are the thick bars that run from your lower control arm to a crossmember a few feet behind them. To crank them you jack up your truck, support it on stands, and turn the bolt clockwise a little at a time...I believe 1 full turn gives you 1/4" of lift. Beware though anything higher then stock and you put more wear on your balljoints and axles. Your upper control arm should be pretty much level at stock height.
Old Mar 26, 2009 | 06:17 PM
rriddle3's Avatar
Shocks are not a factor in ride height, it's all suspension. Can you post a good pic showing how much lower the front end is?
Old Mar 26, 2009 | 06:48 PM
I will get a pic of the truck and yes it is 4WD. The part that sucks is I have pretty much replaced all of the front end; I just had the upper and lower ball joints, pitman arm and a whole bunch of other stuff replaced.
Old Mar 26, 2009 | 07:06 PM
here are the pics, you can see the squat pretty good. I see a lot of other blazers around me and they don't have nearly as much squat.
Old Mar 26, 2009 | 08:44 PM
Sagging torsion bars. Definitely!
Old Mar 26, 2009 | 11:28 PM
Swain's Avatar
+1 Check how many threads you have left on the bolt to raise the torsion bar you could lift it back up maybe but the problem will eventually return.
Oh and a good mechanic should probably have let you know about the torsion bars being that bad before spending mucho denaro on the rest of your front end parts. Maybe consider a new one next time!
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
brino1
Feb 25, 2011 08:05 PM
88s10Blazer
Jan 29, 2010 06:31 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
