Front Hub size
Front Hub size
What is the size of the front hubs with the electric 4x4 ?
thanks
thanks
Could you be more specific?? Are you referring to the size of the front axle retaining nut? If so, it is a 36mm nut.
nop the hub, where the rims sits to make sure the opening from the new rims will fit
Hub, where the axel are held by the nut
are you taking about the center bore.... ?
yes sir !
but then again there are also rims there at 2.765 in....
sweet some i can have the rims i've been eying for a while they have 3" hub center bore
Hopefully they come with the proper spacers. It's best to have hub-centric rims rather than lug-centric as hub-centric is much stronger.
i will buy some hub rings for it to fit good
Flyfishen
15
11-15-2012 06:14 PM
philipbolek
15
01-23-2012 07:08 AM
Renthorin
10-20-2010 08:18 PM
