Front passenger hub assembly
Old May 21, 2017 | 08:36 AM
Raman04's Avatar
Raman04 is on a distinguished road
Default Front passenger hub assembly
Getting a droning sound I believe from the passe ger front, I think the pass side hub/bearing assy is the problem. I have replaced the driver side hub, and upper/lower ball joints a year ago. Would a good test be to turn the hub by hand and see if it grinds, catches on something or not spin freely?
Old May 21, 2017 | 09:38 AM
snuffy's Avatar
snuffy is on a distinguished road
This is how I did it.
Old May 22, 2017 | 08:43 AM
Tajohns34's Avatar
Wheel bearings on these are fairly simple. Just make sure not to buy a cheap hub and bearing assembly. I believe there are some write ups on here that should help out. Also, there is Snuffy's video.
Old Jun 4, 2017 | 09:27 AM
Raman04's Avatar
The old hub was grinding, new hub on as quiet as can be.
Old Jun 4, 2017 | 08:38 PM
I've had mine off so many times between replacing both and pulling everything apart to do ***** joints twice, I can have the old bearing ripped off and the new one back on, Blazer back on all 4's, within 20 minutes, no lie... Took maybe 30 minutes last time I replaced a hub because I used a hydraulic lift at work and the lift was slower to get to chest level than just throwing a floor jack under the front :P
Old Jun 5, 2017 | 02:42 PM
Tajohns34's Avatar
I have done both of mine and had them off to do axles and I could probably have it done in maybe 45 minutes to an hour. I doubt that I would be able to do it in 20 minutes that is for sure.
slickracer34
Mar 12, 2014 05:19 PM
cbur307736
May 5, 2011 07:27 AM
strad
Dec 11, 2010 08:04 PM
Marcin
Apr 13, 2007 01:09 AM
greengoose89
Aug 3, 2006 07:32 AM
