Fuel filter question.
Old Mar 20, 2008 | 08:31 AM
Smoked's Avatar
Smoked is an unknown quantity at this point
Default Fuel filter question.
Okay.. just because there's some debate over where it's located and how much of a job it is... where is it located and how much of a job is it on a 99 blazer zr2 4x4 to change the fuel filter? Is it accessible with the truck jacked up without having to move/drop the gas tank?
Please say it is
Old Mar 20, 2008 | 10:11 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: Fuel filter question.
There are many post about this around there is a tutorial on here I linked below. It should be visbile along the outside of the framerail on the driver side about halfway between the wheels. Its pretty staright forward filter will run you like $10 at walmart. You shouldnt need to jack the truck up to get to it but if you had acess to a lift or something like that im sure it would make it more comfortable. https://blazerforum.com/m_99394/tm.htm
Old Mar 20, 2008 | 10:15 AM
Smoked's Avatar
Thanks!
Old Mar 20, 2008 | 10:18 AM
WolfPack's Avatar
ORIGINAL: portcqb
Minor correction. It is on the inside of the frame rail. And that tutorial is fantastic..shouldn't have any problems if you follow that!
Old Mar 20, 2008 | 08:25 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Thanks for the compliments on the tutorial. Yes it is located on the inside drivers side frame rail. I believe it was 2003 that they mounted the fuel filter in the tank, it might have been the 2004/05 year though that they did that, I can't remember (I saw it somewhere on this forum not to long ago from swartlkk). Its not too hard to do, just about as hard as any other fuel filter.
Old Mar 20, 2008 | 08:45 PM
portcqb's Avatar
So the Zr2 is inside odd, my bravada has it on the outside of framerail. If only GM could make up its mind.
Old Mar 20, 2008 | 09:28 PM
I believe that all s-series trucks have an external fuel filter. It wasn't until the 2005 GMT360/370 platform (trailblazer, envoy, rainier, etc) that they moved to an internal fuel filter.
bigdaddykane93
Jun 25, 2012 01:24 AM
95jblaze
Aug 27, 2011 03:46 PM
brianroark
Jun 25, 2010 03:14 PM
Chalz
Dec 4, 2008 06:11 PM
riverjamie
Sep 24, 2007 08:21 PM
